Hello
Try
'preamble in VBA
    Dim ClientId As String
    ClientId = "{3BDD8D79-2179-4B11-8A5A-257B1C0263AC}"
    Dim iLogicAddIn As ApplicationAddIn
    Set iLogicAddIn = ThisApplication.ApplicationAddIns.ItemById(ClientId)
    Dim iLogicAuto As Object
    Set iLogicAuto = iLogicAddIn.Automation
    If (iLogicAuto Is Nothing) Then
        Call MsgBox("Can not use iLogic")
        Exit Sub
    End If
'Works in iLogic
'''Dim iLogicAuto = iLogicVb.Automation
'''Dim ilogicPath As String() = {"C:\Vault\Testing\", "C:\Vault\Testing2\"}
'''iLogicAuto.FileOptions.ExternalRuleDirectories = ilogicPath
'Doesn't work in VBA
Dim ilogicPath() As String
ilogicPath() = Split("C:\Vault\Testing\,C:\Vault\Testing2\", ",")
R. Krieg
RKW Solutions
www.rkw-solutions.com
