- Mute
- Permalink
- Report
Thanks for trying, but unfortunately that doesn't work. We have similar code in our C# code that worked great in 2019, but stopped working in 2020/2021. Code will let you set the reference to false, but fails when you try to delete it. Appears to be some NOT publicly visible link to the browser node when a face is projected. Unfortunately, when the projected face is no longer available the associated edge loop just kind of disappears for visibility to the API. Interestingly, when I started testing by selecting the browser node and checking what was available under the selection states the selected item is Nothing. I'll submit an error report to ADSK once I get some time to produce a stripped down sample. Was hoping maybe someone else had already ran into this.
William Graham
