johnster100
in reply to: WCrihfield
thanks for the reply.
Most the dimensions i'm removing are retrieved (i'm trying to set up my model so i can retrieve all dimensions required). From what i'm reading this might make it tough, but we'll see.
My only thought was that Autodesk must have a method of doing this within the program as when you use the 'Arrange' command it seems to know what view each dimension comes from. Could someone from Autodesk answer this please?
thanks again,
John
