jR0sal3s
in reply to: dibujocad
this is what i used....resolution at 400 or set it higher.
' Get the PDF translator Add-In.
Dim PDFAddIn As TranslatorAddIn
Set PDFAddIn = ThisApplication.ApplicationAddIns.ItemById("{0AC6FD96-2F4D-42CE-8BE0-8AEA580399E4}")
'Set a reference to the active document (the document to be published).
Dim oDocument As Document
Set oDocument = ThisApplication.ActiveDocument
' Check if the Document Type is a drawing. If it isn't, display a message & exit the Sub.
If (oDocument.DocumentType <> kDrawingDocumentObject) Then
MsgBox "Drawing document not available for Plotting, switch to Drawing Document", , "Drawing not found"
Set oDocument = Nothing
Exit Sub
End If
Dim oContext As TranslationContext
Set oContext = ThisApplication.TransientObjects.CreateTranslationContext
oContext.Type = kFileBrowseIOMechanism
' Create a NameValueMap object
Dim oOptions As NameValueMap
Set oOptions = ThisApplication.TransientObjects.CreateNameValueMap
' Create a DataMedium object
Dim oDataMedium As DataMedium
Set oDataMedium = ThisApplication.TransientObjects.CreateDataMedium
' Check whether the translator has 'SaveCopyAs' options
If PDFAddIn.HasSaveCopyAsOptions(oDocument, oContext, oOptions) Then
' Options for drawings...
oOptions.Value("All_Color_AS_Black") = 0
oOptions.Value("Remove_Line_Weights") = 0
oOptions.Value("Vector_Resolution") = 400
oOptions.Value("Sheet_Range") = kPrintAllSheets
'oOptions.Value("Custom_Begin_Sheet") = 2
'oOptions.Value("Custom_End_Sheet") = 4
End If
