dibujocad
632 Views, 5 Replies
blurred views in PDF exported through the API
I'm using the PDF Translator AddIn via the API to export drawings to PDF. But when I opened the PDF the views appear blurred.
I thought the reason could be that the drawing is exported before being updated. However I tried it, but it still didn't work. I also tried with "DrawingDocument.MakeAllViewsPrecise, but nothing has changed.
Any suggestion?
                    Set oAsmDrawDoc = ThisApplication.ActiveDocument
                    'Update drawing before exporting to PDF
                    oAsmDrawDoc.Update2 (True)
                    'Make all the views precise
                    oAsmDrawDoc.MakeAllViewsPrecise
                    If oAsmDrawDoc.Update2(True) = True Then
                        'Call Sub Export PDF (save drawings as PDF)
                        ExportPDF
                        'Save the updated document
                        oAsmDrawDoc.Save2 (True)
                        'Close AsmDrawDoc and active oAsm again
                        oAsmDrawDoc.Close
                    End If
Thanks in advance
Labels (3)
