WCrihfield
Have you considered that the 499.4 raw number you are supplying may be getting understood as 'database units', instead of your intended 'document' units?  This is a fairly well known issue that a ton of us wish we could eliminate, once and for all, but it persists, due to global use.  Any raw numbers specified within the code, that are in a 'length' scenario, are usually understood by the 'system' as 'database units' (centimeters), instead of whatever length units you may be using within your document.
Try this (set-up to ensure the 499.4 is understood as Inches):  (you could also just use some simple math)
Sub Main
	Dim oDoc As DrawingDocument = ThisDoc.Document
	Dim oSheet As Sheet = oDoc.ActiveSheet
	For Each oDim As DrawingDimension In oSheet.DrawingDimensions
		If oDim.ModelValue <= UnitConv(499.4, UnitsTypeEnum.kInchLengthUnits) Then
			If Round(oDim.ModelValue * 10, 1) -Round(oDim.ModelValue * 10, 0) = 0 Then
				oDim.Precision = 0
			Else
				oDim.Precision = 1
			End If
		Else
			oDim.Precision = 0
		End If
	Next
End Sub
Function UnitConv(oVal As Double, oIntendedUnits As UnitsTypeEnum) As Double
	'just set up to deal with 'Length' type units right now
	'this converts your Inches input to 'database units' so the rule will understand it as intended
	Return ThisApplication.UnitsOfMeasure.ConvertUnits(oVal, oIntendedUnits, UnitsTypeEnum.kDatabaseLengthUnits)
End Function
If this solved your problem, or answered your question, please click ACCEPT SOLUTION.
Or, if this helped you, please click (LIKE or KUDOS) :thumbs_up:.
If you want and have time, I would appreciate your Vote(s) for My IDEAS :light_bulb:or you can Explore My CONTRIBUTIONS
Wesley Crihfield
(Not an Autodesk Employee)
