esaldana
in reply to: WCrihfield
Thank you for helping,
I have create a main sketch where all the sketch points are located... (points are located in the lower sketch)
Then I create all the components were these sketch are projected (just one of the components shown in this picture) the 5 components shown in the top sketch can change sizes (width), some of the points fall in empty space, some within the components...
I then insert a punch (slot) using those sketch points in every component, and then create a pattern to control how many of those oblongs to use per component.
As you can see in the browser I don't really have an error but some exclamation marking where the slots patterns are located, those not cutting the component, I suspect if i change size and these patters fall within the component then the exclamation markings will disappear,
Good thing is that the design doctor is not indicating an error, but is there a way to put a code to take care of those patterns and refresh them once I change the top panels sizes?
Or a better suggestion how to build it differently in order to accomplish the same tasks? I tend to over-complicate things.
Hope this helps,
let me know if you need more clarifications,
