05-26-2021
05:52 AM
- Mute
- Permalink
- Report
05-26-2021
05:52 AM
Is the feature that cuts out slots in sheet metal parts located within some or all of the sheet metal parts, or is the feature located within the assembly? Is this rectangular pattern you mentioned defined within the assembly, or is it defined within some or all of the sheet metal parts. Specifically which type of feature is it that is cutting the slots in the sheet metal parts ('Extrude' sketch as cut, sheet metal 'Cut' feature, or a solid body 'Combine' feature set to cut one solid size/shape out of another solid)?
Wesley Crihfield
(Not an Autodesk Employee)
