esaldana
565 Views, 4 Replies
Sheet metal cuts pattern suppressed if not effect?
I have some sheet metal cut-outs (slots) that goes to several components, the quantities are controlled using rectangular pattern, when some of those slots don't 'cut' some of the components I then have an exclamation mark saying: "One or more feature occurrences failed to execute. Use Edit Pattern to change the pattern definition or use Suppress on the occurrences that failed."
Is there any API or iLogic rule to go trough all the slots in every component from within the assembly or even within the component itself, and suppressed those occurrences that failed to execute?
