dimamazutaMMJ32
609 Views, 4 Replies
iLogic How add to sheets names size of accordant sheet
Hello!
I have drawing with sheets of different sizes.
ActiveSheet.Size give me size of the active sheet and i can't use this command in all cases.
Сan I add the size to the name of the accordant sheets?
A.Acheson
in reply to: dimamazutaMMJ32
Are you looking to get all sheet sizes in a sheet collection and do the following:
  • show the size in the title block or in the drawing as text?
  • Or do you want to put the sheet size into the sheet name?
    Below is a simple loop through the sheets displaying sheet size.
oDrawDoc = ThisApplication.ActiveDocument
    For Each oSheet in oDrawDoc.Sheets
oSheet.Activate
MessageBox.Show(ActiveSheet.Size, "Title")
Next
Regards
Alan
dimamazutaMMJ32
in reply to: A.Acheson
I want to add the sheet size to his name in browser of the sheets.
For example:
01-03 Central plate (A3)
01-03 Central plate (A4)
ActiveSheet.Size writes size of active sheet in all sheets
Hi @dimamazutaMMJ32
here is a quick example.
I hope this helps.
Curtis
oSheets = ThisApplication.ActiveDocument.Sheets
' Loop thru the sheets
For Each oSheet In oSheets
	oName = oSheet.name
	'get only left of the :
	oSplit = Split(oName, ":")
	oName = oSplit(0)
	'get only left of the (
	oSplit = Split(oName, "(")
	oName = oSplit(0)
	'get only left of the )
	oSplit = Split(oName, ")")
	oName = oSplit(0).Trim
	If oSheet.size = 9993 Then
		oSize = " (A0)"
	ElseIf oSheet.size = 9994 Then
		oSize = " (A1)"
	ElseIf oSheet.size = 9995 Then
		oSize = " (A2)"
	ElseIf oSheet.size = 9996 Then
		oSize = " (A3)"
	ElseIf oSheet.size = 9997 Then
		oSize = " (A4)"
	Else
		oSize = ""
	End If
	oSheet.Name = oName & oSize
Next
Just for reference:
DrawingSheetSizeEnum Enumerator
Description
Drawing Sheet Sizes supported by Inventor.
Methods
Name Value Description
k12x18InDrawingSheetSize 9999 12 in x 18 in (typically for architectural drawings).
k18x24InDrawingSheetSize 10000 18 in x 24 in (typically for architectural drawings).
k24x36InDrawingSheetSize 10001 24 in x 36 in (typically for architectural drawings).
k30x42InDrawingSheetSize 10003 30 in x 42 in (typically for architectural drawings).
k36x48InDrawingSheetSize 10002 36 in x 48 in (typically for architectural drawings).
k9x12InDrawingSheetSize 9998 9 in x 12 in (typically for architectural drawings). Default page orientation is Portrait.
kA0DrawingSheetSize 9993 A0 size (typically for metric units).
kA1DrawingSheetSize 9994 A1 size (typically for metric units).
kA2DrawingSheetSize 9995 A2 size (typically for metric units).
kA3DrawingSheetSize 9996 A3 size (typically for metric units).
kA4DrawingSheetSize 9997 A4 size (typically for metric units).
kADrawingSheetSize 9987 A size (typically for inch units).
kBDrawingSheetSize 9988 B size (typically for inch units).
kCDrawingSheetSize 9989 C size (typically for inch units).
kCustomDrawingSheetSize 9986 Custom size. Does (may) not fit one of the standard sizes.
kDDrawingSheetSize 9990 D size (typically for inch units).
kDefaultDrawingSheetSize 9985 Specifies the default setting. The more strongly typed value is the one returned in a query.
kEDrawingSheetSize 9991 E size (typically for inch units).
kFDrawingSheetSize 9992 F size (typically for inch units).
Yes, it works perfect! Thank you!
