WCrihfield
in reply to: marin_israel
After seeing which events you're using, I'm inclined to agree with you, that it doesn't sound like they would be triggered by you manually editing the drawing view.  The thing that raised my suspicion about the add-in was the first line of your original post, where it says the drawing view you are editing was created by the add-in.  Made me think, maybe since it was created by the add-in, there may still be some sort of active reference or related automation.  I know that when you manually edit a base view, it will not only open the 'Drawing View' dialog, but also activate the projected views placement mechanism again.  But usually all you have to do is either click OK on the dialog, or hit the Enter key on the keyboard to end it without loosing your changed settings or progress.  If you're saying that the dialog box isn't present, and therefore you can't click OK ;  or you can't just somehow accept/confirm with Enter, and it's not the add-in causing it, then I'm stumped too.
Wesley Crihfield
(Not an Autodesk Employee)
