209 Views, 1 Reply
Ilogic assembly part creation error
Im getting the error below everytime I run the assembly program for each part created. Any ideas?
Error in rule: CREATION, in document: testpart.ipt
The parameter is incorrect. (Exception from HRESULT: 0x80070057 (E_INVALIDARG))
-----------------ASSEMBLY CODE PORTION---------------------------------------
Components.Add("c:1", "testpart1.ipt")
map.Add("Arg1", SB)
map.Add("Arg2", Width)
map.Add("Arg3", SIDERAIL_T)
map.Add("Arg4", mats)
iLogicVb.RunRule("c:1", "CREATION", map)
Components.Delete("c:1")
--------------------PART CODE----------------------------------------------
UPSTREAM = RuleArguments("Arg1")
DOWNSTREAM = RuleArguments("Arg2")
WIDTH = RuleArguments("Arg3")
THICKNESS = RuleArguments("Arg4")
M = RuleArguments("Arg5")
RADIUS = RuleArguments("Arg6")
LENGTH = UPSTREAM + DOWNSTREAM
'iProperties.Material=Material
If CUT = False Then
iProperties.Value("Project", "Part Number") = "FLOW BLOCK " & M & " - " & LENGTH & " x " & WIDTH & " x " & THICKNESS
iProperties.Value("Project", "Stock Number") = LENGTH & " x " & WIDTH & " x " & THICKNESS
iProperties.Value ("Summary", "Title") =  "FLOW BLOCK " & M & " - " & LENGTH & " x " & WIDTH & " x " & THICKNESS
ElseIf CUT = True Then
iProperties.Value("Project", "Part Number") = "FLOW BLOCK " & M & " - " & LENGTH & " x " & WIDTH & " x " & THICKNESS & " CUT"
iProperties.Value("Project", "Stock Number") = "CUT AS REQUIRED"
iProperties.Value ("Summary", "Title") =  "FLOW BLOCK " & M & " - " & LENGTH & " x " & WIDTH & " x " & THICKNESS & " CUT"
iLogicVb.UpdateWhenDone = True
End If
'define the folder where you want to save the files
oFolder = "C:\Users\ronno\Documents\Inventor\Work\"
'grab the filename
oFileName = iProperties.Value("Summary", "Title") 'without extension
'create the folder if it doesn't exist
If Not System.IO.Directory.Exists(oFolder) Then
    System.IO.Directory.CreateDirectory(oFolder)
End If
'save as a ipt
ThisDoc.Document.SaveAs(oFolder & oFileName & ".ipt", False)
Labels (1)
