gharveyMHN58
779 Views, 2 Replies
Retrieve parent component iProperties in a derived/child component
I am trying to retrieve the part number of the parent component in a derived child component through ilogic, and then pass this to a custom iproperty in the child component.
The parent is the raw material, which is then machined to produce the child. I would like to be able to pull in the part number of the parent to then populate a field in the drawing of the machined part.
Any help is greatly appreciated.
Using Inventor 2022.
Labels (2)
A.Acheson
in reply to: gharveyMHN58
The two of these sources were useful for researching this.
https://forums.autodesk.com/t5/inventor-customization/ilogic-rule-to-include-exclude-derived-paramet...
This one is more in depth copying all iProperties or selected iProperties,
https://forums.autodesk.com/t5/inventor-customization/derived-part-to-copy-multiple-selected-custom-...
However the selected iProperties failed to run for me  so I created the below to just target the iProperty you requested.
If ThisApplication.ActiveDocument.DocumentType <> kPartDocumentObject Then
	MessageBox.Show("Make a Part Document the active document,Exiting", "iLogic")
Else
	Dim oDerDoc As PartDocument
	oDerDoc = ThisApplication.ActiveDocument
	'Look for Derived part components
	If oDerDoc.ComponentDefinition.ReferenceComponents.DerivedPartComponents.Count < 1 Then
		MessageBox.Show("No Derived Part Components in this part", "iLogic")
	ElseIf oDerDoc.ComponentDefinition.ReferenceComponents.DerivedPartComponents.Count > 1 Then
		MessageBox.Show("More than one Derived Part Components in this part,Exiting!", "iLogic")
	Else
		' Set a reference to the part component definition
		Dim oDerCompDef As PartComponentDefinition
		oDerCompDef = oDerDoc.ComponentDefinition
		'Get a reference to derived part components in this part
		Dim oDerComps As DerivedPartComponents
		oDerComps = oDerCompDef.ReferenceComponents.DerivedPartComponents
		Dim oDerComp As DerivedPartComponent
		oDerComp = oDerComps(1)'1st component
		'MessageBox.Show(oDerComp.Name, "iLogic")
		' Get the Reference document.
		Dim oRefDoc As Document
		oRefDoc = oDerComp.ReferencedDocumentDescriptor.ReferencedDocument
'Creates the iProperty in the derived part and assigns the iProperty value of the refDoc iProperties.Value("Custom", "ParentPartNumber") = iProperties.Value(oRefDoc.DisplayName,"Project", "Part Number") MessageBox.Show("iProperty Copied from Parent to Child", "Success") End If End If
I hope that helps.
Regards
Alan
gharveyMHN58
in reply to: A.Acheson
Thank you, that's perfect, does exactly what I was looking for.
Thank you again.
