matt_jlt
in reply to: matt_jlt
This one is for any Autodesk staff, hopefully you can help me out here.
I am testing out messing with the content center + frame generator files via the API. Just starting off with the basics, trying to swap a part from an equal angle profile to an unequal angle profile.
I have replaced all the custom properties below, and it successfully writes to them. But once i right click and select change size, it is still reading the original template and overwrites all the properties again instead of swapping it over.
Can you please tell me what part of the file is controlling the identification of the source template?
Content Library Component Properties
   - *All properties under this property set
Design Tracking Properties
   - Size Designation
   - Categories
Thanks, Matt.
