04-23-2021
07:45 AM
- Mute
- Permalink
- Report
04-23-2021
07:45 AM
Because your in an internal iLogic rule each parameter change will trigger the rule if your seeing the parameter in blue in your logic editor. The apply button is a delay to this operation in order to manually check your data and to allow all data to be filled in without the rule triggering.
if you want to remove this buffer, change the Apply to Done button. Rule runs immediately.
If this solved a problem, please click (accept) as solution.
Or if this helped you, please, click (like)
Regards
Alan
Regards
Alan
