04-22-2021
01:53 PM
- Mute
- Permalink
- Report
04-22-2021
01:53 PM
We will have a large project folder structure. I would like to run an ilogic rule that searches for an excel document named "Title Block Information.xlsx". The rule should START searching where the drawing is saved, if file is found return the path, else back up one level and search again, ect. There may be multiple excel sheets in the folder structure but the rule should always find the one saved closest to the drawing.
Below you will find what I had when I gave up. The issues:
It searches starting at the top of the file structure and searches down to the drawing. I need it to go the other way.
Sub Main
Dim MyDrawDoc As DrawingDocument=ThisDoc.Document
Dim mySavePath As String = GetPath(MyDrawDoc)
End Sub
Private Function GetPath(oDrawDoc As DrawingDocument) As String
Try
Dim sFullDocumentPath As String = IO.Path.GetDirectoryName(oDrawDoc.FullDocumentName)
Dim aPathParts() As String = Strings.Split(sFullDocumentPath, "\")
For i=0 To UBound(aPathParts)
sExcelPathx = sExcelPathx & aPathparts(i) & "\"
msgbox(sExcelPathx)
If System.IO.File.Exists(sExcelPathx & "\Title Block Information.xlsx") Then
sExcelPathx = sExcelPathx & "Title Block Information.xlsx\"
bFound = True
End If
Next
'only return path if folder $Fabrication Data was found
If bfound = True Then
partofpath = Left(sExcelPathx, sExcelPathx.IndexOf(".xlsx"))
Dim sExcelPath As String = partofpath & ".xlsx"
'MsgBox(sExcelPath)
Return sExcelPath
Else
Return Nothing
End Try
End Function
