jacobus
in reply to: Cosmin_V
Hello vaida
please see code below I added a loop to count the drawings haven't tested it.
May not be the most efficient way but hope this helps
' Check that the active document is an assembly file
If ThisApplication.ActiveDocument.DocumentType <> kAssemblyDocumentObject Then
    MessageBox.Show("Please run this rule from the assembly file.", "iLogic")
    Exit Sub
End If
' Define the active document As an Assembly file
Dim oAsmDoc As AssemblyDocument
oAsmDoc = ThisApplication.ActiveDocument
Dim oAsmName As String
oAsmName = Left(oAsmDoc.DisplayName, Len(oAsmDoc.DisplayName) -4)
'- - - - - - - - - - - - -Component Drawings - - - - - - - - - - - -
' Look at the files referenced by the assembly
Dim oRefDocs As DocumentsEnumerator
oRefDocs = oAsmDoc.AllReferencedDocuments
Dim oRefDoc As Document
Dim i As Integer
i = 0
For Each oRefDoc In oRefDocs
    idwPathName = Left(oRefDoc.FullDocumentName, Len(oRefDoc.FullDocumentName) - 3) & "idw"
    ' Check to see that the model has a drawing of the same path and name
    If(System.IO.File.Exists(idwPathName)) Then
     i = i+1
    End If
Next
If i = 0 Then
	MessageBox.Show("No drawings found", "iLogic")
	Exit Sub
ElseIf i > 0 Then
	MessageBox.Show( i + "drawings found", "iLogic")
End If
' Work the the drawing files for the referenced models
' This expects that the model has a drawing of the same path and name
        Dim oDrawDoc As DrawingDocument
        oDrawDoc = ThisApplication.Documents.Open(idwPathName, True)
        oDrawDoc.Update
            oDrawDoc.Save
        oDrawDoc.Close
    End If
Next
