04-20-2021
07:40 AM
- Mute
- Permalink
- Report
04-20-2021
07:40 AM
Hi @RNDinov8r
Looks to me that you just need to change your logic here. We can just assume if it's not found the iProperty then we go straight to creating it. No need to add it as a blank and test for it's value in the same routine; that's likely your issue why it doesn't work; You need to update the document between creating the iProperty and testing for it's value.
The below should work better for you.
Dim ValueList As New List(Of String)({"Round", "Square", "Other" }) ' Add more options here if needed Dim iPropVal As String Try 'See if the iProperty exists currently iPropVal = iProperties.Value("Custom", "Form Factor") Catch ex As Exception 'It doesn't exists, so create it iPropVal = InputListBox("Prompt", ValueList, ValueList.Item(0), Title := "iLogic", ListName := "Form List") If iPropVal Is Nothing Then Return ' User closed form before selecting option iProperties.Value("Custom", "Form Factor") = iPropVal End Try
