04-19-2021
03:06 PM
- Mute
- Permalink
- Report
04-19-2021
03:06 PM
Hello
I've tested it on open document trigger and it works as expected. Can you please try it with this alternative way of adding new iProp?
I assume there's no other rule running? Did you see an error message or does still nothing happen? Are you opening parts separat or are they placed/created in an assembly?
Dim iProp As Inventor.Property
For Each iProp In ThisDoc.Document.PropertySets("{D5CDD505-2E9C-101B-9397-08002B2CF9AE}")
If iProp.Name = "Form Factor" Then Exit For
Next
If iProp Is Nothing Then
'iProperties.Value("Custom", "Form Factor") = ""
ThisDoc.Document.PropertySets("{D5CDD505-2E9C-101B-9397-08002B2CF9AE}").Add("","Form Factor")
End If
If iProperties.Value("Custom", "Form Factor") = "" Then
Dim FormFactor As String = MessageBox.Show("Is this part a round Part?", "Round Stock Info", MessageBoxButtons.YesNo)
If FormFactor = vbYes Then
iProperties.Value("Custom", "Form Factor") ="ROUND"
Else
iProperties.Value("Custom", "Form Factor") ="SQUARE"
End If
End If
R. Krieg
RKW Solutions
www.rkw-solutions.com
