Ralf_Krieg
in reply to: johan.degreef
Hello
The GetObject method gives correct an error if Excel is simply not running and the PathName argument is omitted. Simply add an empty string and GetObject creates a new Excel.Application instance.
ExcelApp = GetObject("", "Excel.Application")
This way is not possible if you want to use a running instance. You can use a try-catch statement
Try
	ExcelApp = GetObject(, "Excel.Application")
	For Each wb In ExcelApp.workbooks
		If UCase(wb.fullname) = UCase(Filename) Then
			Exit For
		End If
	Next
Catch
	GoExcel.Open("C:\Autodesk en Templates\PTN_Part_Library\New_PTN_Part_Library.xlsx")
	'GoExcel.Open("C:\Users\ef\Desktop\New_PTN_Part_Library.xlsx")
End Try
or an On Error Resume next.
On Error Resume Next
opened = False
		opened = True
		Exit For
	End If
Next
If Not opened Then
End If
On Error GoTo 0
R. Krieg
RKW Solutions
www.rkw-solutions.com
