- Mute
- Permalink
- Report
Error in iLogic
All of the sudden this iLogic code gives an error. What i did: I did install Vsual studio to try to learn to code, and therefore I needed to install .net framework 4.8. That is what I have changed. I work on Inventor 2021. I guess it is since then then error pops up.
Imports System.IO
GetInput :
Dim Filename As String = "C:\Autodesk en Templates\PTN_Part_Library\New_PTN_Part_Library.xlsx"
Dim ExcelApp As Object
Dim opened As Boolean
Dim wb As Object
Dim Six_Digit As String
ExcelApp = GetObject(, "Excel.Application")
opened = False
For Each wb In ExcelApp.workbooks
If UCase(wb.fullname) = UCase(Filename) Then
opened = True
Exit For
End If
Next
If Not opened Then
GoExcel.Open("C:\Autodesk en Templates\PTN_Part_Library\New_PTN_Part_Library.xlsx")
'GoExcel.Open("C:\Users\ef\Desktop\New_PTN_Part_Library.xlsx")
End If
Six_Digit = ExcelApp.ActiveCell.Value
If Six_Digit = "" Then
Return
Else If Len(Six_Digit) <> "6" Then
MessageBox.Show("Input must be 6 digits", "ilogic")
GoTo GetInput
End If
Dim oDoc As Document
Dim sFilename As String
'hard code path
oLibrary_Folder = "C:\Autodesk en Templates\PTN_Part_Library\"
Dim oFilenames() As String
oFilenames = System.IO.Directory.GetFiles(oLibrary_Folder, _
"*.*", SearchOption.AllDirectories)
For Each oFilename As String In oFilenames
Dim oFileNameNoExt As String = System.IO.Path.GetFileNameWithoutExtension(oFilename)
If oFileNameNoExt.Contains(Six_Digit) AndAlso oFileNameNoExt.Length = 11 Then
Dim oOptions As Inventor.NameValueMap
oOptions = ThisApplication.TransientObjects.CreateNameValueMap
oDoc = ThisApplication.Documents.OpenWithOptions(oFilename, oOptions, False)
sFilename = oFilename
Exit For
End If
Next
If sFilename = "" Then
MessageBox.Show("No matching libary file found.", "iLogic")
Return
End If
'path from current file
Dim oActiveAssemblyfolder As String = ThisDoc.Path & "\"
'find the postion of the last backslash in the path
Dim FNamePos As Integer = InStrRev(sFilename, "\", -1)
'get the file name with the file extension
Dim oName As String = Right(sFilename, Len(sFilename) -FNamePos)
'get the file name (without extension)
Dim ShortName As String = Left(oName, Len(oName) -4)
'get extension
Dim oExt As String = Right(oName, 4)
Dim oNewName As String = ShortName & "_" & System.DateTime.Now.ToString("yyyyMdHHmmss")
Dim oPathandName As String = oActiveAssemblyfolder & oNewName & oExt
oDoc.PropertySets.Item("Design Tracking Properties").Item("Part Number").Value = ShortName
'save new document
oDoc.SaveAs(oPathandName, True)
oDoc.Close
'[ Place Component
Dim oAsmCompDef As AssemblyComponentDefinition
oAsmCompDef = ThisApplication.ActiveDocument.ComponentDefinition
' Create Matrix
Dim oMatrix As Matrix
oMatrix = ThisApplication.TransientGeometry.CreateMatrix
Call oMatrix.SetTranslation(ThisApplication.TransientGeometry.CreateVector(50, 50, 50), True)
'insert new occurence
'Dim oOcc As ComponentOccurrence
'oOcc = oAsmCompDef.Occurrences.Add( _
'oPathandName, oMatrix)
ThisApplication.CommandManager.PostPrivateEvent(PrivateEventTypeEnum.kFileNameEvent, oPathandName)
ThisApplication.CommandManager.ControlDefinitions.Item("AssemblyPlaceComponentCmd").Execute
- Mute
- Permalink
- Report
Arthur Knoors
Autodesk Affiliations:
- Mute
- Permalink
- Report
Try to uninstall 4.8! Think that you don't need that for testing your code!
Arthur Knoors
- Mute
- Permalink
- Report
I think i deleted all 4.8 stuff, but still not working. Now there is 5.0 too and some ASP.NET stuff.
Can that be safely deleted too?
- Mute
- Permalink
- Report
Create a restore point first.
Normally you can uninstall that without issues.
If not restore your machine to the restore point.
Regards
Arthur Knoors
- Mute
- Permalink
- Report
Hello
The GetObject method gives correct an error if Excel is simply not running and the PathName argument is omitted. Simply add an empty string and GetObject creates a new Excel.Application instance.
ExcelApp = GetObject("", "Excel.Application")
This way is not possible if you want to use a running instance. You can use a try-catch statement
Try
Exit For
End If
Next
Catch
End Try
or an On Error Resume next.
On Error Resume Next
opened = False
opened = True
Exit For
End If
Next
If Not opened Then
End If
On Error GoTo 0
R. Krieg
RKW Solutions
www.rkw-solutions.com
- Mute
- Permalink
- Report
Thx, but I tried both option, giving other errors.
This code was working fine.
There is always an instance open of excel (the sheet where I pick my number)
- Mute
- Permalink
- Report
i have reinstalled excel, reinstalled inventor 2021. Nothing seems to bring this helpfull tool back to life. Don't know where to look further...
On my collegues PC it runs without any issue.
- Mute
- Permalink
- Report
Do you have show fileextensions on?
Arthur Knoors
- Mute
- Permalink
- Report
@bradeneuropeArthur wrote:Do you have show fileextensions on?
no
- Mute
- Permalink
- Report
It must have something to do with user rights, because if I run inventor as adminsitrator, it works. But I cannot do that all the time, because of access rights to sharded network drives.
- Mute
- Permalink
- Report
Try it with fileextensions on!
Arthur Knoors
- Mute
- Permalink
- Report
Can you share the complete code.
Including the add references!
Arthur Knoors
- Mute
- Permalink
- Report
Changed:
Imports System.IO
GetInput :
Dim wb As Object
opened = False
opened = True
Exit For
End If
Next
If Not opened Then
End If
Return
GoTo GetInput
End If
'hard code path
Exit For
End If
Next
Return
End If
'get extension
'save new document
oDoc.Close
'[ Place Component
' Create Matrix
Arthur Knoors
- Mute
- Permalink
- Report
Did that help?
Arthur Knoors
- Mute
- Permalink
- Report
Did that help?
No
- Mute
- Permalink
- Report
Test dit eens:
Welke messages krijg je:
Imports System.IO
GetInput :
Dim wb As Object
Msgbox ("A")
opened = False
Msgbox ("B")
opened = True
Msgbox ("C")
Exit For
End If
Next
If Not opened Then
Msgbox ("D")
Msgbox ("Excel six Digit " & Six_Digit)
Return
GoTo GetInput
End If
'hard code path
Msgbox ("E ")
Exit For
End If
Next
Return
End If
Msgbox ("F ")
'get extension
Msgbox ("G ")
Msgbox ("H ")
'save new document
oDoc.Close
Msgbox ("I")
'[ Place Component
Msgbox ("J ")
' Create Matrix
Msgbox ("K ")
Msgbox ("L ")
Msgbox ("M ")
Arthur Knoors
- Mute
- Permalink
- Report
"A", and then it crashes
- Mute
- Permalink
- Report
first start excel.
than run the code.
What messages do you get now?
Arthur Knoors
- Mute
- Permalink
- Report
@bradeneuropeArthur @Ralf_Krieg I always start excel first. The intention of the ilogic code is to select an excel cell with a 6 digit number in, so the result is an "A"
I don't think the problem lies in the code. It has to do with user rights or installation of excel/inventor. But I can't find what.
