RNDinov8r
954 Views, 14 Replies
How to determine the "form factor" of a part
So, I have been able to create a method, using the metadata that iPropWiz spits out, to determine the raw stock size of all the material of the custom parts on our machines. iPropWiz spits out the extents box of each and every part created. The intent is to use the qty and size info to generate a list to send to our material vendors. All of that to say, how do I determine if a part is round? I know that if a part has two identical dimensions, it could be round, say x&y or x&z are 20  and 20 mm each, it coudl be round. I flag those parts and the job will verify if the part is truly made from round stock.
What I havent' been able to easily determine is what aobut a shaft that is a "D" shaft, (some flat all along the length, such that it's made from say Ø20mm material, with 1mm removed from one side ). Or a shaft that has a continuous keyway...
If these were short peices and only one or two each req'd this wouldn't be a big deal, but if I have to make say, 5 D shafts at 24" long from 316 SS (Ø25mm) and I order square stock instead, that's an expensive mistake.
All that to say, is there an easy (or not easy) way to maybe have an iLogic code run "on save" that writes to an iProperty that actually says the part is round.
At this point, I am just lookign for methods, not necessarily even code.
I had thought of creating a template that HAS to be used for round parts, such that it's iProprty of, say, "Round Stock" was always set to yes, while parts made from the normal template would be set to "no". However, now I have to rely on 6-7 engineers always remember to use the correct template for "round" parts...
