04-13-2021
12:00 PM
- Mute
- Permalink
- Report
04-13-2021
12:00 PM
Hello
I don't mean more than 99 slots per feature, but more than 99 features. If there is an feature "SL100", the code fails. Just want to say, don't except it's perfect.
For hole features you could try to count the holecenterpoints. If such a center point is positioned out of your volume and you drill "a hole in the air" this hole would even be counted.
Dim oDoc As PartDocument = ThisApplication.ActiveDocument
Dim oUserParams As UserParameters = oDoc.ComponentDefinition.Parameters.UserParameters
Dim iCount As Integer
Dim sCount As String
' If a feature is Active (not suppressed), it is added the FeatureList array
For Each oExtrusion As ExtrudeFeature In oDoc.ComponentDefinition.Features.ExtrudeFeatures
If oExtrusion.Name.StartsWith("SL") Then
If Feature.IsActive(oExtrusion.Name) Then
sCount = Mid(oExtrusion.Name, 3)
If sCount.Length = 1 Then
sCount = "0" & sCount
End If
MsgBox("Number_of_Slots_" & sCount & ": " & oExtrusion.Definition.Profile.Count)
Try
Parameter("Number_of_Slots_" & sCount)= oExtrusion.Definition.Profile.Count
Catch
oUserParams.AddByExpression ("Number_of_Slots_" & sCount, oExtrusion.Definition.Profile.Count, UnitsTypeEnum.kUnitlessUnits)
End Try
End If
End If
Next
For Each oHole As HoleFeature In oDoc.ComponentDefinition.Features.HoleFeatures
If oHole.Name.StartsWith("Hole_") Then
If Feature.IsActive(oHole.Name) Then
sCount = Mid(oHole.Name, 6)
End If
MsgBox("Number_of_Holes_" & sCount & ": " & oHole.HoleCenterPoints.Count)
Try
Parameter("Number_of_Holes_" & sCount)= oHole.HoleCenterPoints .Count
Catch
oUserParams.AddByExpression ("Number_of_Holes_" & sCount, oHole.HoleCenterPoints.Count, UnitsTypeEnum.kUnitlessUnits)
End Try
End If
End If
Next
R. Krieg
RKW Solutions
www.rkw-solutions.com
