Just a couple of thoughts:
Maybe you can have your Inventor document's parameters 'linked' to an external Excel type spreadsheet document (.xls or .xlsx), that way you can interact with the externally referenced parameters document without needing Inventor.
Or have the routine set-up within your Inventor document, where it automatically exports its Parameters to an XML document when you save/close it, then import that XML when it opens.  That way you can mess with the parameters within the XML document without Inventor, then have the result show the next time you open the Inventor document.
If this solved your problem, or answered your question, please click ACCEPT SOLUTION.
Or, if this helped you, please click (LIKE or KUDOS) :thumbs_up:.
Wesley Crihfield
(Not an Autodesk Employee)
