A.Acheson
in reply to: Alex.Shechter
That's simple enough to achieve. I have assumed this is in a part. Each extrusion name will need to be unique so something like SL1-1, SL1-2 etc SL1 to identify the slot size and 1,2,3 to uniquely identify each one .
Quicky modified it from this post.
https://forums.autodesk.com/t5/inventor-forum/ilogic-feature-counting/td-p/8659430
If you place this rule in the document and set event trigger to on Save or model parameter change.
The down side is you need to rename the extrusion name in the browser.
Dim oDoc As PartDocument
oDoc = ThisApplication.ActiveDocument
Dim ExtrusionList As New ArrayList
' If a feature is Active (not suppressed), it is added the FeatureList array
For Each oExtrusion In oDoc.ComponentDefinition.Features.ExtrudeFeatures
	If oExtrusion.Name.Contains("SL1")  Then
		If Feature.IsActive(oExtrusion.Name) Then
		   ExtrusionList.Add(oExtrusion.Name)
		End If
	End If
Next
' Count the number of items in the FeatureList array
Dim FeatureCount As Integer
FeatureCount = ExtrusionList.Count
'Turn off these message boxes if not needed.
MessageBox.Show(FeatureCount, "iLogic")
d0 = InputListBox("Prompt", ExtrusionList, d0, Title := "Title", ListName := "List")
'Places the FeatureCount value into the User parameter
Parameter("Extrusion_Slots1") = FeatureCount
Regards
Alan
