04-06-2021
11:16 AM
- Mute
- Permalink
- Report
04-06-2021
11:16 AM
Hi! This can be done in two ways (quite similar to manual process). You can edit the Flange and change the type (click on double-arrow button) to Edge or Width. Set the desirable distance accordingly.
For iLogic/API, you will need to alter the Flange type and change the parameters programmatically. Or, you change the Flange type before starting the rule. Then you only need to change the parameter values.
Many thanks!
Software Test Engineer
