- Mute
- Permalink
- Report
Hi @shrey9GP3F. That won't be possible using an iLogic Form and iLogic rule(s).
You might accomplish something like that with a VBA UserForm when created within the VBA Editor, but it will be quite a bit more complicated than the iLogic Form route. It has a visual design set of tools to work with, but requires a special 'form module' to accompany it (where you specify the specifics of its design and contents), besides the regular module for the regular part of the code.
Another thing you could try, if the form's design is fairly simple, is create your own Windows Form within the same rule that you want to interact with its outcome. It's also quite a bit more complicated than the iLogic Form route, but it might result in the behavior you are seeking.
Here is a link to one of my contribution posts, in which I show (with an example) how create, show, and react to, a Windows Form, all within one iLogic rule.
If this solved your problem, or answered your question, please click ACCEPT SOLUTION.
Or, if this helped you, please click (LIKE or KUDOS)
If you want and have time, I would appreciate your Vote(s) for My IDEAS
or you can Explore My CONTRIBUTIONS
Wesley Crihfield
(Not an Autodesk Employee)
