04-04-2021
12:47 PM
- Mute
- Permalink
- Report
04-04-2021
12:47 PM
It seems this line is the issue. You had not accessed the text to initiate the replacement.
oRow.Item("DATE") = Now
I changed this line to get it to work.
oRow.Item("DATE").Text = Now
I used this link to trace the issue
https://forums.autodesk.com/t5/inventor-customization/ilogic-revision-tables/td-p/7548318
Here is another way to write this statement and declares the RevisionTableCell
Dim oDoc As Document = ThisApplication.ActiveDocument Dim oSheet As Sheet = oDoc.ActiveSheet Dim oTable As RevisionTable = oSheet.RevisionTables.Item(1) Dim oRows As RevisionTableRows = oTable.RevisionTableRows Dim oRow As RevisionTableRow = oRows.Item(oRows.Count) Dim oCell4 As RevisionTableCell 'Get Cell to modify, Use ("Date") or (4) is date Column# counted from the left oCell4 = oRow.Item("Date") oCell4.Text = Now.ToShortDateString MsgBox("Revision Date: " & oCell4.Text)
Here is a few more date related formatting that could be useful.
'This will use computers default date formatting which maybe standardized across multiple applications by your IT department. MessageBox.Show(Today, "Title") 'https://forums.autodesk.com/t5/Inventor-forum/ilogic-Date-format/td-p/2720101 'This allows a customization of the date by changing string variable e.g "d","F" MessageBox.Show(DateTime.Now.ToString("D"), "Title") MessageBox.Show(DateTime.Now.ToString("F"), "Title") 'Search bewlow page to sub heading "Format strings and DateTimeFormatInfo properties" this will customize date format 'https://docs.microsoft.com/en-us/dotnet/api/system.globalization.datetimeformatinfo?view=net-5.0
If this solved a problem, please click (accept) as solution.
Or if this helped you, please, click (like)
Regards
Alan
Regards
Alan
