A.Acheson
I have assumed your are running this in a local rule. The issue here seems to be the event trigger for the rule. The view rep when changed manually isn't triggering the rule to run.
To change this behavior. I had to create a parameter for the view rep and place into a form(optional) When the ViewRep parameter value is changed the rule is triggered  and the active view rep is changed. Then the conditional statement runs. The attached assembly shows this working.
'' set a reference to the assembly component definintion.
'' This assumes an assembly document is open.
Dim oAsmCompDef As AssemblyComponentDefinition
oAsmCompDef = ThisApplication.ActiveDocument.ComponentDefinition
'define view rep collection
Dim oViewReps As DesignViewRepresentations
oViewReps = oAsmCompDef.RepresentationsManager.DesignViewRepresentations
'define view rep
Dim oViewRep As DesignViewRepresentation
oViewRep = oAsmCompDef.RepresentationsManager.ActiveDesignViewRepresentation
Dim oViewRepName As String
oViewRepName = oViewRep.Name
'Activate  viewrep via parameter selected
oViewReps.Item(ViewRep).Activate
'check names
If oViewRepName = "open" Then
		d21 = "840"
		d32 = "180"
Else
		d21 = "0"
		d32 = "0"
End If
'RuleParametersOutput()
'InventorVb.DocumentUpdate()
Regards
Alan
