03-31-2021
05:59 PM
- Mute
- Permalink
- Report
03-31-2021
05:59 PM
@Anonymous
There must be something up with the code. Can you post it here? I haven’t done much assembly creation with ilogic parts but I am guessing it would be a lot of code.
Is it a case that you will need the parts to change sizes based on set parameter of assembly or is it all manual sizing?
Using ilogic for part numbers,descriptions etc will need to be either hard coded or taken from an excel sheet along with parameters.
So in essence you are trading one container for information for another but dropping the derived part element and member file updating.
If this solved a problem, please click (accept) as solution.
Or if this helped you, please, click (like)
Regards
Alan
Regards
Alan
