bradeneuropeArthur
430 Views, 4 Replies
Deactivate Object Not Working
Deactivation these after deactivate does not work
oTab = Nothing
When I start the Addin again the tab is still there after deactivate.
What is wrong in the code.
Public Sub SetupUserInterface(ByVal addInSiteObject As Inventor.ApplicationAddInSite, ByVal firstTime As Boolean, ClientID As String)
oTab = oRibbon.RibbonTabs.Add(sName & "", "AknoorsMasterAddIn" & "", ClientID)
End Sub
Public Sub Deactivate() Implements Inventor.ApplicationAddInServer.Deactivate
            ' This method is called by Inventor when the AddIn is unloaded.
            ' The AddIn will be unloaded either manually by the user or
            ' when the Inventor session is terminated.
            ' TODO:  Add ApplicationAddInServer.Deactivate implementation
            m_inventorApplication = Nothing
            oTab = Nothing
            System.GC.WaitForPendingFinalizers()
            System.GC.Collect()
End Sub
Arthur Knoors
Autodesk Affiliations:
Consider adding the following into Deactivate() implementation:
oTab.Delete()
oTab = Nothing
Thank you,
Alex Korzun
Inventor-Revit Interop / Inventor-Fusion Interop / Inventor ETO
Autodesk, Inc.
Also then it is not released.
when you enable the add in again then the Tab is still in there and gives an error.
Arthur Knoors
I tested the .Delete call, and it works.
Created an assembly, and added two rules into it:
  1. AddRibbonTab
    Dim rib As Ribbon = ThisApplication.UserInterfaceManager.Ribbons("Assembly")
    Dim test As RibbonTab = rib.RibbonTabs.Add("Test","{A4C2F061-0DC3-46A5-8B31-508938EDB5B1}", "{A4C2F061-0DC3-46A5-8B31-508938EDB5B1}")
    Dim panel As RibbonPanel = test.RibbonPanels.Add("Update", "{DF5AA47C-1858-41D7-92B9-CB4BBB1BADF3}", "{A4C2F061-0DC3-46A5-8B31-508938EDB5B1}")
    Dim button As ButtonDefinition = ThisApplication.CommandManager.ControlDefinitions.Item("AppLocalUpdateCmd")
    panel.CommandControls.AddButton(button, True)
    The Tool tab is created with Update command in it
  2. DeleteRibbonTab
    Dim test As RibbonTab = rib.RibbonTabs("{A4C2F061-0DC3-46A5-8B31-508938EDB5B1}")
    test.Delete()
The "Test" tab is removed.
The rules should be run one after another.
Otherwise, the first rule fails on the second run, as RibbonTab is attempted to be created the second time.
The second rule will fail on the second run, in attempt to find non-existent RibbonTab.
Thank you,
Alex Korzun
Autodesk, Inc.
The deletes you do in the deactivate routine?
Arthur Knoors
