03-29-2021
09:52 AM
- Mute
- Permalink
- Report
03-29-2021
09:52 AM
I was thinking about making this run automatically after open. For that I'd want to identify if my Custom Table already exists so I don't keep pasting over the top of it.
I'm extremely new to ilogic so I may not even be on the right track here, but this is what I came up with.
It'll recognize a named custom table if it has one, but if it doesn't have one, it'll error out. If I run just the portion after the the if statement separately, it works. I'm guessing it has to do with the declarations, but I'm stumped if this can be fixed? (I made a few other changes to specify the sheet but that I don't think is the issue). If I'm way off track, no worries, but I thought I would ask.
If ThisApplication.ActiveDocumentType <> DocumentTypeEnum.kDrawingDocumentObject Then Exit Sub End If Dim oDDoc As DrawingDocument = ThisApplication.ActiveDocument Dim oSheet As Sheet oSheet = oDDoc.Sheets(2) Dim oRevTable As CustomTable oRevTable = oSheet.CustomTables.Item(1) If oRevTable.Title = ("REVISION HISTORY - LEGACY") Then Exit Sub End If Dim oRevTbl As RevisionTable = oSheet.RevisionTables.Item(1) Dim oTitle As String = "REVISION HISTORY - LEGACY" Dim oPos As Point2d = ThisApplication.TransientGeometry.CreatePoint2d(27.0815,27.145) Dim oRowCount As Integer = oRevTbl.RevisionTableRows.Count Dim oColCount As Integer = oRevTbl.RevisionTableColumns.Count Dim oCellCount As Integer = oRowCount * oColCount Dim oColTitles(oColCount - 1) As String Dim oColWidths(oColCount - 1) As Double Dim oRowHeights(oRowCount - 1) As Double Dim oCellContents(oCellCount-1) As String Dim oRow, oCol, oCell As Integer For oRow = 1 To oRowCount For oCol = 1 To oColCount oCellContents(oCell) = oRevTbl.RevisionTableRows.Item(oRow).Item(oCol).FormattedText oCell = oCell+1 oColTitles(oCol - 1) = oRevTbl.RevisionTableColumns.Item(oCol).Title oColWidths(oCol - 1) = oRevTbl.RevisionTableColumns.Item(oCol).Width Next oRowHeights(oRow - 1) = oRevTbl.RevisionTableRows.Item(oRow).Height Next Dim oCTable As CustomTable oCTable = oSheet.CustomTables.Add(oTitle, oPos, oColCount, oRowCount, oColTitles, oCellContents, oColWidths, oRowHeights)
