03-29-2021
12:02 AM
- Mute
- Permalink
- Report
03-29-2021
12:02 AM
I found a solution, but it is only working if i Run it as 2 separately codes:
Firstly the ID number is updated:
' Update ID Number ' Item Number = ID Number doc = ThisDoc.Document Dim oAssyDef As AssemblyComponentDefinition = doc.ComponentDefinition Dim oBOM As BOM = oAssyDef.BOM oBOM.StructuredViewEnabled = True Dim oBOMView As BOMView = oBOM.BOMViews.Item("Structured") ' Set the Row Merge Settings oBOM.SetPartNumberMergeSettings(False) Dim oBOMRow As BOMRow For Each oBOMRow In oBOMView.BOMRows 'Set a reference to the primary ComponentDefinition of the row Dim oCompDef As ComponentDefinition oCompDef = oBOMRow.ComponentDefinitions.Item(1) Dim CompFullDocumentName As String = oCompDef.Document.FullDocumentName Dim CompFileNameOnly As String Dim index As Integer = CompFullDocumentName.LastIndexOf("\") CompFileNameOnly = CompFullDocumentName.Substring(index + 1) Try ItemNumber = oBOMRow.ItemNumber Parameter(CompFileNameOnly, "ID_Number") = ItemNumber Catch End Try Next iLogicVb.UpdateWhenDone = True
Secondly an Asset Tag is made, which updates the all asset models:
AddReference "Autodesk.Factory.PublicAPI.dll" Imports Autodesk.Factory.PublicAPI.Currency.v2
Sub Main() ' set a reference to the assembly component definintion. ' This assumes an assembly document is open. Dim oAsmCompDef As AssemblyComponentDefinition oAsmCompDef = ThisApplication.ActiveDocument.ComponentDefinition 'Set up a variable for the component cccurrence Dim oOcc As ComponentOccurrence, factoryInstance As IAssetInstance 'Access the Browser and Activate the "Bim Content" Browser Pane Dim oBrowserPanes = ThisApplication.ActiveDocument.BrowserPanes Dim Model_Browser_Pane As BrowserPane = oBrowserPanes.Item("Model") Dim oOccNode As BrowserNode For Each oOcc In oAsmCompDef.Occurrences Try If (Not IsFactoryInstance(ThisApplication.ActiveDocument, oOcc, factoryInstance)) Then MessageBox.Show(oOcc.Name & " is NOT a Factory Asset", "Title") Else oOccNode = Model_Browser_Pane.TopNode.BrowserNodes.Item(oOcc.Name) oOccNode.DoSelect ChangeAssetTag(ThisApplication.ActiveDocument, oOcc, factoryInstance) End If Catch End Try Next End Sub 'Use this Function To see If the models are Assets Function IsFactoryInstance(layoutDoc As Document, oOcc As ComponentOccurrence, ByRef factoryInstance As IAssetInstance) Dim instances = Autodesk.Factory.PublicAPI.API.Instance.GetAssetInstances(layoutDoc) found = False For Each instance In instances If instance.NativeObject.Equals(oOcc) Then factoryInstance = instance found = True Exit For End If Next Return found End Function 'The public subroutine will allow the editing of Asset Tags Public Sub ChangeAssetTag(layoutDoc As Document, oOcc As ComponentOccurrence, Asset_Instance As IAssetInstance) For Each grp In Asset_Instance.PropertyGroups If grp.Name = "AssetTag" Then For Each prop In grp.Properties If prop.Name = "Asset Tag" Then New_Value = Parameter(oOcc.Name, "ID_Number") & " - " & iProperties.Value(oOcc.Name, "Project" ,"Part Number") prop.Value = New_Value End If Next End If Next 'After changed some value, you need To update the instance Dim ins() As IAssetInstance={Asset_Instance} Autodesk.Factory.PublicAPI.API.Instance.UpdateAssetInstances(layoutDoc,ins) End Sub
Is it possible to merge these two codes and improve them?
I would like the code to save computer capacity and work faster.
Thanks in Advance
