03-28-2021
06:54 PM
- Mute
- Permalink
- Report
03-28-2021
06:54 PM
iPart are a derived file so you would simply create the variants in the iPart and publish the members then select the members in the iAssembly. You can select the members via ilogic if required.
Otherwise just use ilogic to create a configurator. I believe you can't have a custom iAssembly like you can have a custom ipart.
Have you sample part files or code to work with? You said 100,00, is it 100, 1000 variants?
If this solved a problem, please click (accept) as solution.
Or if this helped you, please, click (like)
Regards
Alan
Regards
Alan
