400 Views, 5 Replies
iPart parameter change within iAssemblies
I am trying to create an iAssembly with iParts for bricks within a custom furnace. The issue im having is the bricks needed have over 100,00 variations in size. Is there a way to use an iPart called in an iAssembly for one parameter and then change the other two other parameters within the assembly as static values calculated with the code. The bricks are in increments of 0.125 in all three directions. This is being used for automation purposes.
Labels (3)
