Ralf_Krieg
Hello
It's quite difficult to understand what you are doing exactly. Is it possible to post a demofile?
Anyway, Inventor can define an A-Side for flat pattern. Usually this is not changed by users in parametric parts where users change only parameters like length, width, hole count or something similar. The A-Side object has a face property which could be used.
Can you proof if the A-Side definition can be used to "mark" your face? If so, we can start to code the script.
R. Krieg
RKW Solutions
www.rkw-solutions.com
