1189 Views, 10 Replies
Export surface to dxf-file with iLogic
Hopefully someone can help me with exporting a surface to a dxf-file.
At this moment I'm exporting a sketch of a unfolded sheetmetal surface with some holes to a dxf-file. However when the number of holes is changing the sketch is not automatically updated and therefore not all the holes are included in the  dxf-file. So perhaps there is a trick to automatically update the projected geometry of a surface in a sketch?
Other option is to export a surface, but I cant achieve this. I have made a offset surface and this surface is automatically update when the number of holes has changed, so far so good, however I'm struggling with the code to export it to DXF, hopefully someone can help.
Maybe there is another way to go?
Thanks!
