03-12-2021
10:43 AM
- Mute
- Permalink
- Report
03-12-2021
10:43 AM
If you want the rule to run on all drawings before save, I would recommend adding it in the Drawings tab in the Event Triggers dialog. If you do that, then you don't need to run a rule to add it to individual drawings.
But if the rule isn't working well, is it really a good idea to add it to an event trigger?
There is a way to run the UI command from a rule. Please look at this post:
https://clintbrown.co.uk/2020/07/11/ilogic-centre-arrange-dimensions/
The only problem with that is that the rule will only run on full Inventor. If you ever want to upload your model to the cloud and have your rule run on the cloud, then you will have to disable that rule.
Mike Deck
Software Developer
Autodesk, Inc.
