MjDeck
in reply to: Charlies_3D_T
@Charlies_3D_T , are you saying that your original rule worked better for this particular drawing? What happens if you run your original rule again?
I just did a test with a drawing that looks something like yours. I don't see dimensions arranged on top of each other (like the 1255 over 1005 that you show), but I also don't see an arrangement that is as good as what I can get with the Arrange command in the UI. Unfortunately, it looks like the API method is not as good as the UI command.
Mike Deck
Software Developer
Autodesk, Inc.
