Charlies_3D_T
1150 Views, 10 Replies
Ilogic Center and Arrange dimensions but exclude dimensions under an angle
I have following code for centering and arranging my dimensions.
Sub Main
Dim oDoc As DrawingDocument
oDoc = ThisDoc.Document
' Set a reference to the active sheet
Dim oSheet As Sheet
oSheet = oDoc.ActiveSheet
Dim oDrawingDim As DrawingDimension
Dim oDrawingDims As DrawingDimensions
Dim oDimsToBeArranged As ObjectCollection
' Iterate over all dimensions in the drawing and
' center them if they are linear or angular.
' Add them to the ObjectCollection to be arranged
oDrawingDimensions = oSheet.DrawingDimensions
oDimsToBeArranged = ThisApplication.TransientObjects.CreateObjectCollection
For Each oDrawingDim In oDrawingDimensions
    If TypeOf oDrawingDim Is LinearGeneralDimension Then
       oDrawingDim.CenterText
       oDimsToBeArranged.Add(oDrawingDim)
    End If
Next
If oDimsToBeArranged.Count > 0 Then
	oDrawingDimensions.Arrange(oDimsToBeArranged)
End If
End Sub
I have 2 things i want to add:
1) i want to be able to center an ordinate set also?
2) i have some dimensions under an angle and i want to exclude these angles. Is this possible? (see picture)
Hope some of you can help me out with this one.
