03-08-2021
11:07 AM
- Mute
- Permalink
- Report
03-08-2021
11:07 AM
Save as DXF from IDW - only on drawing change
So, this is code that is a baked in snippet wiht iLogic. (Running 2020.3.4). I am curious as to why this always creates a new dxf. (I have it trigger after Save as an external rule) when the code snippet that creates STEP files only updates the STEP if the .ipt/.iam has changed.
Is there a way to make this only update when/if the IDW change.
' Get the DXF translator Add-In. Dim DXFAddIn As TranslatorAddIn DXFAddIn = ThisApplication.ApplicationAddIns.ItemById("{C24E3AC4-122E-11D5-8E91-0010B541CD80}") 'Set a reference to the active document (the document to be published). Dim oDocument As Document oDocument = ThisApplication.ActiveDocument Dim oContext As TranslationContext oContext = ThisApplication.TransientObjects.CreateTranslationContext oContext.Type = IOMechanismEnum.kFileBrowseIOMechanism ' Create a NameValueMap object Dim oOptions As NameValueMap oOptions = ThisApplication.TransientObjects.CreateNameValueMap ' Create a DataMedium object Dim oDataMedium As DataMedium oDataMedium = ThisApplication.TransientObjects.CreateDataMedium ' Check whether the translator has 'SaveCopyAs' options If DXFAddIn.HasSaveCopyAsOptions(oDocument, oContext, oOptions) Then Dim strIniFile As String strIniFile = "C:\temp\dxfout.ini" ' Create the name-value that specifies the ini file to use. oOptions.Value("Export_Acad_IniFile") = strIniFile End If 'Set the destination file name oDataMedium.FileName = ThisDoc.PathAndFileName(False) & ".dxf" 'Publish document. DXFAddIn.SaveCopyAs(oDocument, oContext, oOptions, oDataMedium) 'Launch the dxf file in whatever application Windows is set to open this document type with
Additionally, I have noticed that if my IDW is only one sheet, it will automatically overwrite the file, but if it is more than one sheet - it will force me to acknowledge that I want to overwrite each sheet. Why does that occur?
