OK. Maybe try it this way then.
Sub Main
	'source document
	Dim oSDoc As PartDocument = ThisApplication.ActiveDocument
	Dim oSUParams As UserParameters = oSDoc.ComponentDefinition.Parameters.UserParameters
	Dim oSUParam As UserParameter
	'target document
	Dim oTDoc As AssemblyDocument = ThisApplication.Documents.Add(kAssemblyDocumentObject, "{source Assy filepath}", True)
	Dim oTUParams As UserParameters = oTDoc.ComponentDefinition.Parameters.UserParameters
	Dim oTUParam As UserParameter
	For Each oSUParam In oSUParams
		If Not oSUParam.IsKey Then Continue For 'so it will only process Key params
		If oSUParam.Units = "ul" Then
			oTUParam = oTUParams.AddByExpression(oSUParam.Name, oSUParam.Value, "ul")
			oTUParam.IsKey = True
			CopyExpList(oSUParam,oTUParam)
		ElseIf oSUParam.Units = "Text" Then
			oTUParam = oTUParams.AddByValue(oSUParam.Name, oSUParam.Value, kTextUnits)
		Else
			oTUParam = oTUParams.AddByValue(oSUParam.Name, oSUParam.Value, kMillimeterLengthUnits)
		End If
	Next
End Sub
Public Sub CopyExpList(oSourceP As UserParameter, oTargetP As UserParameter)
	If oSourceP.ExpressionList IsNot Nothing AndAlso oSourceP.ExpressionList.Count > 0 Then
		oTargetP.ExpressionList.SetExpressionList(oSourceP.ExpressionList.GetExpressionList)
	End If
End Sub
If this solved your problem, or answered your question, please click ACCEPT SOLUTION.
Or, if this helped you, please click (LIKE or KUDOS) :thumbs_up:.
Wesley Crihfield
(Not an Autodesk Employee)
