@danny.lewisA9QBW
If you are using iLogic below code will help you.
CopyParam is a parameter in which you will copy the multivalue list.
SourceParam is a parameter in which there is already a multivalue list.
MultiValue.List("CopyParam") = MultiValue.List("SourceParam")
RuleParametersOutput
InventorVb.DocumentUpdate
 See if this helps.
If this answer has solved your problem please ACCEPT SOLUTION and hit like if you found it helpful..!
Dutt Thakar
LinkedIn
