Hello
Which row of your Code is right? It seems you mixed two scripts together.
Is your script called by another script or should it run alone? I assume you calling this script by a Main sub. You will have to fill the string variables for template name and output path. There is a shared variable "VPR_Codice" and I assume it is set elsewhere. There is a variable "pathOutputLamieraDXF" used, but not set anywhere.
I've commented unused code.
Perhaps it will help, otherwise you have to post more details. It didn't run correctly is a little bit less information. :winking_face:
Sub Main()
	Dim IPT_OM_Template As String = ""	'<--- Fill missing Text
	Dim pathOutputDXF As String = ""		'<--- Fill missing Text
	Call Print_Assembly_IPT_DXF(IPT_OM_Template, pathOutputDXF)
End Sub
'IPT_OM_template is the name of Assembly in the rule
Sub Print_Assembly_IPT_DXF(IPT_OM_Template As String, pathOutputDXF As String)
	Dim oAsm As AssemblyDocument = ThisDoc.Document
	'Dim oPenDoc As Document=ThisDoc.Document
	Dim AsmCompDefMainL0 As AssemblyComponentDefinition = oAsm.ComponentDefinition 'ThisApplication.ActiveDocument.ComponentDefinition
	Dim AsmCompDefL1 As AssemblyComponentDefinition '= ThisApplication.ActiveDocument.ComponentDefinition
	Dim OccurMainL0 As ComponentOccurrence
	Dim OccurL1 As ComponentOccurrence
	'Dim AsmCompMainL0 As ComponentDefinition = ThisDoc.Document.ComponentDefinition
	'Dim AsmCompMainL1 As ComponentDefinition = ThisDoc.Document.ComponentDefinition
	For Each OccurMainL0  In AsmCompDefMainL0.Occurrences
		Dim oOccNameL0 As String = OccurMainL0.Name
		Dim thisAssembly As AssemblyDocument = oOccNameL0
		Logger.Info("Apro assieme per DXF: " & oOccNameL0)
		If OccurMainL0.Definition.Type = ObjectTypeEnum.kAssemblyComponentDefinitionObject Then
			For Each OccurL1 In OccurMainL0.SubOccurrences
			'For Each doc In thisAssembly.AllReferencedDocuments
				If OccurL1.Definition.Type=ObjectTypeEnum.kSheetMetalComponentDefinitionObject Then
					Dim parsedPartName = OccurL1.ReferencedDocumentDescriptor.DisplayName ' doc.DisplayName
					Logger.Info("Selezionare parte da esportare in DXF: " & parsedPartName)
					If parsedPartName.Contains("CTG") Then
						Logger.Info("Ho selezionato la parte in CTG")
					Else
						Logger.Info("Ho selezionato la parte in lamiera")
						Dim sOut      As String = "FLAT PATTERN DXF?AcadVersion=2004&OuterProfileLayer=OUTER_PR​OFILE&OuterProfileLayerColor=0;0;0&InteriorProfilesLayer=INNER_PROFILE&InteriorProfilesLayerColor=0;0;0&InvisibleLayers=IV_BEND;IV_BEND_DOWN;IV_UNCONSUMED_SKETCH;IV_ARC_CENTERS;IV_TANGENT;IV_ROLL;IV_ROLL_TANGENT;IV_ALTREP_BACK;IV_ALTREP_FRONT;IV_FEATURE_PROFILES_DOWN;IV_FEATURE_PROFILES;IV_TOOL_CENTER;IV_TOOL_CENTER_DOWN;DIGI_MARKER_TOOL_1;DIGI_MARKER_TOOL_2"
						Dim component As SheetMetalComponentDefinition = OccurL1.Definition
						'Dim PathDXF As String = pathOutputLamieraDXF & iProperties.Value(OccurL1, "Custom", "Nome_File")
						component.Unfold
						If System.IO.File.Exists(pathOutputDXF) = True Then
							System.IO.File.Delete(pathOutputDXF)
						End If
						'component.DataIO.WriteDataToFile(sOut, pathDXF)
						component.DataIO.WriteDataToFile(sOut, pathOutputDXF )
						Logger.Info("DXF " & SharedVariable("VPR_Codice") & " SUCCESS")
						component.FlatPattern.ExitEdit()
						'component.Document.close()
					End If
				End If
			Next
		End If
	Next
End Sub
R. Krieg
RKW Solutions
www.rkw-solutions.com
