Hi @danny.lewisA9QBW .
See if this code does what you're trying to do:
Sub Main
	'define source document
	Dim oSourceDoc As Document = ThisApplication.ActiveDocument
	'get its parameters
	Dim oSParams As Inventor.Parameters = GetParams(oSourceDoc)
	Dim oSParam As Inventor.Parameter
	'define target document
	Dim oTargetDoc As Document
	Dim oTargetDocName As String = GetTargetDoc
	If oTargetDocName = "" Then Exit Sub
	oTargetDoc = ThisApplication.Documents.Open(GetTargetDoc, True)
	'get its parameters
	Dim oTParams As Inventor.Parameters = GetParams(oTargetDoc)
	Dim oTParam As Inventor.Parameter
	For Each oSParam In oSParams
		If Not oSParam.IsKey Then Continue For
		Try
			oTParam = oTParams.Item(oSParam.Name)
		Catch
			If oSParam.ParameterType = ParameterTypeEnum.kModelParameter Then
				oTParam = oTParams.ModelParameters.AddByExpression(oSParam.Expression, oSParam.Units, oSParam.Name)
				If oSParam.ExpressionList IsNot Nothing AndAlso oSParam.ExpressionList.Count > 0 Then
					Dim oExps() As String = oSParam.ExpressionList.GetExpressionList
					oTParam.ExpressionList.SetExpressionList(oExps)
				End If
			ElseIf oSParam.ParameterType = ParameterTypeEnum.kUserParameter Then
				oTParam = oTParams.UserParameters.AddByExpression(oSParam.Expression, oSParam.Units, oSParam.Name)
				End If
			End If
		Catch
			MsgBox("Failed to copy source param named '" & oSParam.Name & "' to target document.",,"")
		End Try
	Next
End Sub
Public Function GetParams(oDoc As Document) As Inventor.Parameters
	'check doc type
	Dim oDocType As DocumentTypeEnum = oDoc.DocumentType
	'get its Params
	Dim oPrms As Inventor.Parameters
	If oDocType = DocumentTypeEnum.kPartDocumentObject Or _
		oDocType = DocumentTypeEnum.kAssemblyDocumentObject Then
		oPrms = ThisApplication.ActiveDocument.ComponentDefinition.Parameters
	ElseIf oDocType = DocumentTypeEnum.kDrawingDocumentObject Then
		oPrms = ThisDrawing.Document.Parameters
	End If
	Return oPrms
End Function
Public Function GetTargetDoc() As String
	'use Open File Dialog to get target document
	Dim oFileName As String
	Dim oDoc As Inventor.Document
	Dim oFileDialog As Inventor.FileDialog
	ThisApplication.CreateFileDialog(oFileDialog)
	oFileDialog.DialogTitle = "Select 'Target' file."
	oFileDialog.InitialDirectory = ThisApplication.DesignProjectManager.ActiveDesignProject.WorkspacePath
	oFileDialog.Filter = "Autodesk Inventor Files (*.iam;*.dwg;*.idw;*.ipt:*.ipn;*.ide) | *.iam;*.dwg;*.idw;*ipt;*.ipn;*.ide | All files (*.*)|*.*"
	oFileDialog.MultiSelectEnabled = False
	oFileDialog.OptionsEnabled = False
	oFileDialog.CancelError = True
	oFileDialog.InsertMode = False
	On Error Resume Next
	oFileDialog.ShowOpen
	If Err.Number <> 0 Then
		MsgBox("Dialog was canceled. Exiting.", vbOKOnly, "CANCELED")
		Return ""
	Else
		If oFileDialog.FileName <> vbNullString Then
			oFileName = oFileDialog.FileName
			Return oFileName
		Else
			MsgBox("No file was selected. Exiting.", vbOKOnly + vbExclamation, "FILE NOT SELECTED")
			Return ""
		End If
	End If
End Function
If this solved your problem, or answered your question, please click ACCEPT SOLUTION.
Or, if this helped you, please click (LIKE or KUDOS) :thumbs_up:.
If you have time, please... Vote For My IDEAS :light_bulb:or you can Explore My CONTRIBUTIONS
Inventor 2021 Help | Inventor Forum | Inventor Customization Forum | Inventor Ideas Forum
Wesley Crihfield
(Not an Autodesk Employee)
