03-03-2021
12:12 PM
- Mute
- Permalink
- Report
03-03-2021
12:12 PM
Dim dwg As Inventor.DrawingDocument = ThisDrawing.Document
Dim v As Inventor.DrawingView = dwg.ActiveSheet.DrawingViews.Item(1)
'v.ReferencedDocumentDescriptor.ReferencedDocument
Dim a As Inventor.PartDocument = v.ReferencedDocumentDescriptor.ReferencedDocument 'ThisDoc.Document
If a.SubType = "{9C464203-9BAE-11D3-8BAD-0060B0CE6BB4}" Then
Dim s As Inventor.SheetMetalComponentDefinition = a.ComponentDefinition
Dim f As Inventor.FlatPattern = s.FlatPattern
Dim fl As Inventor.FlatPatternOrientation = f.FlatPatternOrientations.Item(1)
If fl.FlipBaseFace = False Then
fl.FlipBaseFace = True
ElseIf fl.FlipBaseFace = True
fl.FlipBaseFace= False
End If
dwg.Update
End If
Arthur Knoors
Autodesk Affiliations:
