Or use this to flip it back an forward:
Dim a As Inventor.PartDocument = ThisDoc.Document
If a.SubType = "{9C464203-9BAE-11D3-8BAD-0060B0CE6BB4}" Then
	Dim s As Inventor.SheetMetalComponentDefinition = a.ComponentDefinition
	Dim f As Inventor.FlatPattern = s.FlatPattern
	Dim fl As Inventor.FlatPatternOrientation = f.FlatPatternOrientations.Item(1)
	If fl.FlipBaseFace = False Then
		fl.FlipBaseFace = True
		ElseIf fl.FlipBaseFace = True
			fl.FlipBaseFace= False
		End If
	End If
Arthur Knoors
Autodesk Affiliations:
