bradeneuropeArthur
Dim a As Inventor.PartDocument = ThisDoc.Document
'Dim su As Inventor.DocumentTypeEnum = a.DocumentSubType
If a.SubType = "{9C464203-9BAE-11D3-8BAD-0060B0CE6BB4}" Then
	Dim s As Inventor.SheetMetalComponentDefinition = a.ComponentDefinition
	Dim f As Inventor.FlatPattern = s.FlatPattern
	'f.FlatPatternOrientations.ActiveFlatPatternOrientation.FlipAlignmentAxis
	Dim fl As Inventor.FlatPatternOrientation = f.FlatPatternOrientations.Item(1)
	fl.FlipBaseFace= True
	'MsgBox ("")
	End If
Arthur Knoors
Autodesk Affiliations:
