@Guido.LangeTuchscherer
If you are thinking about finding a specific LOD that is there in the assembly or not, you may be able to use For loop and iterate the collection of LODs and check if the one you are looking for exists or not and if it exists, Inventor will be able to activate it, and if it does not it can create it.
Are you looking for something like that?
If this answer has solved your problem please ACCEPT SOLUTION and hit like if you found it helpful..!
Dutt Thakar
LinkedIn
