- Mute
- Permalink
- Report
You know that you can change that in the flat-pattern definition within inventor!?
Or do you need it with coding?
And do you need it in i-logic; VBA; Vb.net; or else?
Regards
Arthur Knoors
Autodesk Affiliations:
